HI,
 I'm currently interested in Building a new PC but am confused as to which Chipset I should use. Is X99 Worth it or what would be the best value? I am planning on building an entire new build except I am going to temporarily migrate my current GPU which is a Asus HD 7790, until nVidia release their next range of cards.. or GTX 980s become cheaper.
My current budget is £550~ for everything excluding a Graphics Card and a SSD. But overall  I would have about ~£1000 for the entire build
Here is the Case I plan on using
Thanks :D
Midori:
Specs: Intel i5 4690K | Asus Strix GTX 1070 |  2x4gb Corsair Vengeance DDR3 @1600MHz| Samsung 850 Pro 250GB | WD Blue 1TB | EVGA Supernova G2 750W | NZXT H440 Black/Green
Cooling:|2 Stock NZXT Case fans | 2 Noctua F-A14 FLXNoctua NF-P14S-1200 |
Peripherals: Corsair LUX RGB K70 Silent| Corsair RGB Sabre | Audio Technica M40X
OS: Windows 10 Pro 64bit
https://linustechtips.com/topic/331093-need-help-with-a-new-build/
HI,
Thanks :D
it will be a while before nvivida releases a new series of gpus. just wait, amd is supposed to release new gpus soon
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
HI,
Thanks :D
Welcome to the forums! If you only have 1000, X99 is out of your budget anyway. Here's what I'd recommend:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£174.00 @ Amazon UK)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  (£115.99 @ Aria PC)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory  (£53.10 @ CCL Computers)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£80.97 @ Amazon UK)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  (£273.59 @ Aria PC)
Case: NZXT H440 (Green/Black) ATX Mid Tower Case  (£84.99 @ Amazon UK)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£90.11 @ Amazon UK)
Total: £911.09
Generated by PCPartPicker 2015-03-19 19:01 GMT+0000
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
Will DDR3 RAM be okay for about the next 4 years? Is there really any advantage to DDR4?
Also Should I upgrade now or should I wait until the summer? Does it matter?
I have so many questions xD
Thanks
Midori:
http://uk.pcpartpicker.com/p/HdPmK8
this is about what i'd get for that price (as requested) without SSD and GPU for £550
i wasnt sure if you needed a HDD or not, but a 2TB or even 1TB drive should squeeze into budget, if not, lower the ram to 8GB (2x4GB) and you have some more headroom.
(16GB is probably overkill to start with)
and to answer your question: DDR3 will be fine, as much as the CPU you buy will be fine.
EDIT: welcome to the forum, congrats on such a well-explained first post.
How about this build? It's without the SSD and GPU :P An i5 would be good enough for light photo editing and using FL Studio, Right?
Would you advise I reuse my old RAM as well It's 2 4GB sticks of Patriot DDR3? It's only 1333 MHz though..
And am I right in saying CPUs aren't really a factor for bottlenecking in games just The GPU?
Midori:
Thanks;D, just wordering what really is the difference between all the Asus Z97 boards, e.g. a, pro, deluxe etc?
Midori:
After Some more research, here is my "Final" Build
http://uk.pcpartpicker.com/p/xfkLnQ
Obviously I'll be adding an SSD and new GPU in the future :P
Midori:
