Advice on how to find this?
Go to playback devices
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/329591-sound/#findComment-4474295
Tells me nothing is plugged in for sound -_-
Right click and select show disabled devices
https://linustechtips.com/topic/329591-sound/#findComment-4474327
And now what?
Well usually there is just one HDMI output.
I guess just enable all of them and see if one of them works.
https://linustechtips.com/topic/329591-sound/#findComment-4474389
I can't enable them
What other devices show up there besides those ones?
https://linustechtips.com/topic/329591-sound/#findComment-4474413
That's it
What hardware are you running?
https://linustechtips.com/topic/329591-sound/#findComment-4474427
msi gaming 3 board and the card is a 270x
vizio smart tv is my monitor...
Try using the catalyst control center
https://linustechtips.com/topic/329591-sound/#findComment-4474451
Something I need to download?
Should be on the computer already, it's AMDs control center for their cards.
It shows up when I right click my desktop and click graphics properties.
https://linustechtips.com/topic/329591-sound/#findComment-4474474
