I've noticed recently I get quite horrible fps drop in BF4. I'm playing normally and suddenly the FPS drops to like 20 and pretty much stays there. This has forced me to quit games and its overall quite frustrating since it makes the game almost unplayable when it happens.
I checked afterburner and noticed that the GPU usage starts to go all over the place all of a sudden, which appears to be causing this. Its not a hardware issue, as both CPU and RAM were not maxed out at the time this began. Its also not a temperature issue, with CPU temps in the 50s-60s and GPU temps in the high 40s at the time. Here's an afterburner screenshot:
Does anyone know how to fix this?
https://linustechtips.com/topic/329330-bf4-sudden-fps-drop/
Do a clean reinstall of the drivers.
Fixed an issue with bf4 for me.
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
https://linustechtips.com/topic/329330-bf4-sudden-fps-drop/#findComment-4470905
Something similar happened to my 290 on BF4 as well, I think it was an unstable overclock (may or may not be the same for you).
I am running a conservative overclocked, but its stable for everything else and its not even close to where I can push my 290 if I give it more voltage. I hope that's not the issue, but I'll try playing at stock settings and see if that helps.
https://linustechtips.com/topic/329330-bf4-sudden-fps-drop/#findComment-4470953
Try core unparking, I had similar issue and after unparking cores it stopped.
CPU-delided i5-4670k@4.6Ghz 1.42v R.I.P (2013-2015) MOBO-Asus Maximus VI Gene GPU-Gigabyte GTX 970 G1 Gaming@1582Mhz core/3744Mhz memory COOLING-Corsair H60 RAM-1x8Gb Crucial ballistix tactical tracer@2133Mhz 11-12-12-26  DRIVES-Kingston V300 60Gb, OCZ trion 100 120Gb, WD Red 1Tb
2nd  fastest i5 4670k in GPUPI for CPU - 100M
https://linustechtips.com/topic/329330-bf4-sudden-fps-drop/#findComment-4470996
