Pc Build for $1500
Solved by Str_Mape,
I'd recommend this it has the peripherals that're good enough but if you want higher end peripherals you're going to have to make sacrifices elsewhere in the build.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($317.85 @ OutletPC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($99.99 @ Newegg)
Memory: PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory ($104.86 @ Amazon)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive ($80.98 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive ($44.00 @ Amazon)
Video Card: Zotac GeForce GTX 980 4GB AMP! Edition Video Card ($523.99 @ Amazon)
Case: BitFenix Neos White/Red ATX Mid Tower Case ($32.99 @ NCIX US)
Power Supply: Corsair CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($56.50 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Monitor: Acer G227HQLbi 60Hz 21.5" Monitor ($119.99 @ Micro Center)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($26.99 @ NCIX US)
Total: $1498.12
Generated by PCPartPicker 2015-03-16 16:58 EDT-0400
