I've recently being overclocking my 5820K, it was originally sitting at 4Ghz at all times. I've pushed it up to 4.7 stable, for around a week. I'd start my computer and my bios would tell me my overclock is unstable and it would turn off. I'd restart and enter the bios, change the multiplier to 4.6 and then reboot, and it booted just fine. I'd then restart and change it to 4.7Ghz, it would work for a week and then become unstable again. I'd put it back to 4.6Ghz, run it again and it would be fine. But, around a week ago it said that the 4.6GHz was unstable. I have turned my ram overclock on and off and there is no difference. They are running in XMP. This is really odd, can someone give me a hand with this?
i7 5820K
Asus X99 PRO
CoolerMaster Nepton 280L (Seated with Arctic Silver 5.)
Galax HoF 980
Intel 730 Series 240GB
Seagate Barracuda 3TB
EVGA 750 Supernova G2 Gold
| Intel i7 5820K @ 4.8GHz | G.Skill Ripjaws 4X4GB | X99 PRO | HoF 980 | Asus MX299Q | Sennheiser HD600 |
https://linustechtips.com/topic/328268-5820k-overclocking-issues/
-snip-
What are you voltage settings? CPU, Cache (also called ring), VCCIN, System Agent, etc.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
CPU voltage is 1.4, and everything else is at stock clocks.
O_o
Pushin it a little hard for 24/7 use. 4.7 is likely not going to be stable, even at that voltage. To get my 5960X stable I had to up the System Agent voltage to 1.15v, VCCIN (input voltage) to 1.88v, and VCCIO CPU to I believe 1.1v, I'll grab some BIOS screens when I get back from dinner. Just be aware that 4.7 on any Haswell-E is hard to get 24/7 stable w/out going a little nuts with all the voltage settings. Mine won't even get past POST w/1.55v @46 <_<
O_o
Ahhh. Well thank you.
I will take it down to 45 and see how it goes.
