Using Android device as a modern/router
Go to solution Solved by Prikk,
Yes that will be used in case of emergency only. Any idea how to set this up?
You will need a device that is compatible with Ethernet over USB. Check if your android device has an Ethernet option in the Wireless/Connection settings, or just try to look it up online. If it does, just find a Ethernet -> USB cable and plug it in.
I haven't tried that. But I'm guessing no. You can use your phone as a mobile hotspot but you'd be using you phone's data.
better off buying a cheap router.
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
From DSL? No.
From LTE/3G, maybe
i5-4690k @ 4.2GHz | Asus Radeon R9 290 DirectCU II | Hyper 212 EVO | ASRock Z97 Extreme3 | Corsair Vengeance 8GB 1866MHz, Corsair XMS 4GB | 850 EVO 250GB, random 1TB drive | Corsair 200R | EVGA SuperNOVA 750W | Rosewill RK-9000BR | Logitech G700s | Logitech G930 | ViewSonic VG2427wm, Dell S2209W, Dell S2009W
Dell Inspiron 3147
Latitude E5420, Samsung 840 EVO 250gb, 12gb RAM, 1600x900 display
Pentium G3258 @ 3.2GHz | WD Red 2TB x3 in RAID-Z, Crucial MX100 128GB(cache drive) | Fractal Design Node 304 | Gigabyte GA-H97N-WIFI | Crucial Ballistix Sport 8GB | EVGA 500B
HTC One M8 64GB, Droid Razr M
Replace? No.
Substitute in emergency? Yea.
The chip on phones are no where near as powerful as those in routers. You will Lag, and you will lag a lot. Connect like 5-6 devices on it and it will be unusable.
Replace? No.
Replace? No.
It's not that bad. I can easily play online games while on hotspot with 3g, ping being 50
I don't always have time to study, but when I do, I don't.
