Hi Guy,
I'm planning a CPU loop in my NZXT h440. I measured everything out so i know it all will fit in. Im just no sure about the components. I have Intel Core i5-3570.
Here they are:
Fans: Cooler Master JETFLO 120 x2
CPU water block: EK Supreme LTX-Acetal CSQ water block
Radiator: EK-coolstream PE 249
Tubing: Primoflex Advanced Tubing 13/10 clear
Coolant: EK Ekoolants blood red
Fittings: EK Water Blocks EK-XSQ fitting 10/13 (3/8", 1/2") G1/4 black
Will the parts fit and am I missing anything?
Thx in advnace!
https://linustechtips.com/topic/326964-first-loop/
https://linustechtips.com/topic/326964-first-loop/#findComment-4443257
you can mount a bay res by make mounting whole or holding bracket in the H440.  Just don't see a reason to do so tho.
H440 has very limited space for res/pump mounting option.  Mostly it will be at the place where HDD cages were supposed to be.  I would suggest you to get a D5+tube res combo. and drill mounting wholes.
https://linustechtips.com/topic/326964-first-loop/#findComment-4444000
