I'm building my first PC by following along with this video (https://youtu.be/d_56kyib-Ls?t=14m48s). The video recommends assembling all the pieces outside the case first just to make sure all the parts work and mine do. I attach the Graphics card, RAM, CPU, Cooler and PSU together, make sure all the plugs are fitted right, and just like in the video I get the motherboard splash screen after about 8 or so seconds.
But when I reassemble the parts *inside* the case, no splash screen.
I've considered just transferring the MB whole into the case with everything attached but I didn't want to run the risk of breaking it before asking.
 Graphics Card-GeForce GTX 960
PSU - CORSAIR CX series CX500 500W
RAM - 1 x Pareema 8GB (2 x 4GB)
CPU - Intel Core i5
MB | H81M-E35 V2
Edit: Ok, I got it to work. The only change I made was removing an extra MB braket that I had put on my case.
https://linustechtips.com/topic/326598-internal-v-external-build-issues/
if it runs outside your case it should run inside the case.  Just be sure you have everything plugged in correctly.  That is really the biggest issue I see rigth now.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
