Hi! I want to build my first desktop computer. Coud you chek my build components, is it evrything okay. Thank you very much :)
CPU:
Intel® Core™ i7-4790 Processor  http://www.intel.com/buy/us/en/product/components/intel-core-i7-4790-processor-8m-cache-400-ghz-392803
Case:
Graphite Series 230T Windowed Compact Mid-Tower Case
http://www.corsair.com/en/graphite-series-230t-windowed-compact-mid-tower-case-battleship-grey
GPU:
ASUS STRIX-GTX960-DC2OC-2GD5 GeForce GTX 960 2GB 128-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121913&ignorebbr=1&cm_re=PPSSLQEGPIKMNK-_-14-121-913-_-Product
Hard drive:
Western Digital WD10EZRX Caviar Green HardDisk
http://www.amazon.it/Western-Digital-WD10EZRX-Caviar-HardDisk/dp/B006GDVREI/ref=sr_1_3?ie=UTF8&qid=1426093212&sr=8-3&keywords=Western+Digital
Power supply:
HX Series HX650 Power Supply — 650 Watt 80 PLUS® Gold Certified Modular PSU
http://www.corsair.com/en/hx-series-hx650-power-supply-650-watt-80-plus-gold-certified-modular-psu
RAM:
Vengeance® — 4GB Dual Channel DDR3 Memory Kit
http://www.corsair.com/en/vengeance-4gb-dual-channel-ddr3-memory-kit-cmz4gx3m2a2000c10
Motherboard:
Asus Z87 PRO LGA 1150 Motherboard
http://www.amazon.com/Asus-Z87-PRO-1150-Motherboard/dp/B00CRJSXR4
https://linustechtips.com/topic/326251-help-for-first-pc-buid/
Don't get the 960 unless you want to save electricity.
CPU I7 - 4720HQ RAM 2 x 8GB • GPU Nvidia GTX 850M Storage 250GB 850 EVO - 1TB Seagate Hybrid
Keyboard CM Storm QuickFire Rapid-I (MX brown) & Pok3r (MX clear) • Mouse Logitech G502 • Sound Audio-Technica ATH-M50X • OS Windows 10 Pro - Linux Arch
Storage Asustor AS7004T
https://linustechtips.com/topic/326251-help-for-first-pc-buid/#findComment-4431374
What could you offer to me?
R9 280X
https://linustechtips.com/topic/326251-help-for-first-pc-buid/#findComment-4431644
CPU:
Case:
GPU:
Hard drive:
Power supply:
RAM:
Motherboard:
I suggest an i7-4690k, EVGA GTX 970, and at least 8gb ram is a MUST for a content creation/gaming build. You could always pick up a 500gb HDD and get an SSD later. i7-4790 will NEVER reach its full potential with 4gb ram and a 960
https://linustechtips.com/topic/326251-help-for-first-pc-buid/#findComment-4432250
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($256.99 @ Amazon)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($74.78 @ Newegg)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($109.99 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($94.99 @ Adorama)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($44.99 @ Amazon)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($323.98 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($44.85 @ OutletPC)
Total: $1000.56
Generated by PCPartPicker 2015-03-11 17:44 EDT-0400
https://linustechtips.com/topic/326251-help-for-first-pc-buid/#findComment-4433501
Did it support Nvidia 3D vision? I like to try stereoscopic gaming. :)
No but it does support HD3D, same thing but by AMD. You'll still need a 3D capable screen of course.
Here is a fairly old video about it where Linus explains what it is:
I do however think 3D will only be a headache and probably quite literally so.
https://linustechtips.com/topic/326251-help-for-first-pc-buid/#findComment-4440279
Total: $1000.56
This
- The xeon is a i7 without integrated graphics for a much lower price.
- No point in z87/z97 board if the CPU cant even overclock.
- GTX970: more powerrrrrrrr
- HX powersupply is not worth it (esp at this budget)
- 4GB RAM is way too low. 8GB is recommended for gaming and 16GB for video editing.
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
https://linustechtips.com/topic/326251-help-for-first-pc-buid/#findComment-4441154
Why no to ASUS? i agree with the G1 gaming, but why EVGA over ASUS Strix on a 960 card
https://linustechtips.com/topic/326251-help-for-first-pc-buid/#findComment-4444778
Well, ASUS is higher on the benchmarks than the EVGA ;) Also, it has better heatpipes and better temps :) smaller too.
This is a moot point.  Unless OP has a Shield, or need Cuda cores for 3d modeling, the 960 is always the wrong choice.  The 960 is the wrong choice here simply because his budget allows for a 970.
https://linustechtips.com/topic/326251-help-for-first-pc-buid/#findComment-4444990
