building a nas
Solved by brandishwar,
If you're going to be using random hard drives, you'll either want to set them up as separate volumes on the NAS, or configure them together as a JBOD -- "just a bunch of disks" -- which is basically where one partition can span disparate drives. Also make sure you're going to have a good network connection to it so that it's talking at gigabit speeds on your network and not 100Mb/s, just to ensure the best throughput.
