just the tower ? or with monitor ?
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429335
Budget - $400
Needs - gaming and blender
My old laptop is just too crappy (intel hd graphics 1st gen)
Small renders are taking just too long(I know rendering on laptops is not good but no choice)
Please help guys need your advice!
Do yourself a favor and save up more money.  :)
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429337
Budget - $400
prefered place of order,country,do you need peripherals,os?
CPU:Intel I5 6700k (4.7GHz)  Mobo:Asus maximus viii hero RAM:HyperX 16GB  GPU:MSI gtx1080 Gaming X
Case:Fractal Design Define S SSD:Kingston 240GB HDD:1TB & 2TB raid 0 PSU:Corsair RMX750 Cooling:H100i v2 OS:Windows 10
Display:Benq GL2440,LG 29" Keyboard:Tesoro Durandal Mouse:Deathadder Sound:2.1 GENESIS NCS-0856, PC-37X, Razer manowar
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429339
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429354
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($49.99 @ Micro Center)
Motherboard: ASRock B85 Anniversary ATX LGA1150 Motherboard  ($64.99 @ Amazon)
Video Card: Sapphire Radeon R7 260X 2GB Video Card  ($97.98 @ Newegg)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  ($22.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($37.99 @ NCIX US)
Total: $390.81
Generated by PCPartPicker 2015-03-11 07:41 EDT-0400
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429386
This is not so bad:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($173.61 @ OutletPC)
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($52.99 @ Amazon)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($58.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($44.99 @ Best Buy)
Video Card: Sapphire Radeon R9 280X 3GB Video Card  ($192.98 @ Newegg)
Case: Thermaltake Versa H21 ATX Mid Tower Case  ($32.29 @ Directron)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Micro Center)
Total: $615.84
Generated by PCPartPicker 2015-03-11 07:42 EDT-0400
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429392
Chopped down a bit:
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($109.75 @ OutletPC)
Memory: Crucial Ballistix Sport 4GB (1 x 4GB) DDR3-1600 Memory  ($30.48 @ Amazon)
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card  ($169.99 @ Newegg)
Total: $500.48
Generated by PCPartPicker 2015-03-11 07:44 EDT-0400
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429406
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-2133 Memory ($68.98 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($47.89 @ OutletPC)
Total: $390.81
Blender uses cuda very efficiently
Open gl not so much
So I could really use a nvidia gpu right?
Or is open gl performance good too in blender?
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429416
Chopped down a bit:
Total: $500.48
Cool build! But a 100$ out of budget equates to 180$ out of budget in India
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429425
Open gl not so much
little hard putting nvidia gpu in that budget :/
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  ($124.99 @ NCIX US)
Total: $417.82
Generated by PCPartPicker 2015-03-11 07:54 EDT-0400
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429455
can you up your budget to 450$ ? since you using blender so i try put i3 and 750Ti and price still 50$ over budget
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($103.98 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($44.85 @ OutletPC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Video Card  ($124.99 @ NCIX US)
Total: $451.67
Generated by PCPartPicker 2015-03-11 07:57 EDT-0400
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429476
or instead gimme your local store pc website and your local budget
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429481
Total: $417.82
I'll just upgrade it to an i3 will it be okay?
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429483
Total: $451.67
this is what im talking about, i3 + 750ti :) gg
get this
https://linustechtips.com/topic/326120-first-build-please-help/#findComment-4429493
