no just gaming aha is the i5 just as good for gaming then?
-vDemonnnz
There is maybe a 5-10 fps difference
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/325913-first-pc/#findComment-4426452
-vDemonnnz
Do you have a lot of disposable income?
If not you could get a PC with pretty much all the performance of what you put together for around 1000 quid instead.
"Common sense is not so common." -Voltaire
https://linustechtips.com/topic/325913-first-pc/#findComment-4426459
okay, not really but i dont know pc parts very well im just going on what ive read on forums and on youtube vids. Could you suggest me a build then?
-vDemonnnz
https://linustechtips.com/topic/325913-first-pc/#findComment-4426508
-vDemonnnz
Sure no problem. Just wait 5 mins and I'll send you a link.
https://linustechtips.com/topic/325913-first-pc/#findComment-4426519
Thanks man.
-vDemonnnz
Sorry I took a while:
PCPartPicker part list: http://uk.pcpartpicker.com/p/NcDsBm
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (£143.94 @ Aria PC) (i5 is plenty good for gaming or almost anything else. overclocking the i5s is not really worth it IMO when you consider the additional heat, power consumption and price)
Motherboard: MSI Z87I AC Mini ITX LGA1150 Motherboard  (£47.78 @ CCL Computers) (excellent motherboard with built in AC wifi. Very cheap yet good)
Memory: GeIL Black Dragon 16GB (2 x 8GB) DDR3-1333 Memory  (£89.27 @ Amazon UK) (the corsair one was also good but unless you have a windowed case you won't be seeing the RAM anyway. This one still looks cool and is a bit cheaper)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£79.50 @ Scan.co.uk)  (same)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£38.34 @ Aria PC) (just as fast as WD black. The whole WD black thing is silly when WD blues and Barracudas provided the same performance for a lot less. The SSD is what makes the difference, not the brand of 7200rpm HDD)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX Video Card  (£262.76 @ Scan.co.uk) (same)
Case: Cooler Master Elite 130 Mini ITX Tower Case  (£38.12 @ Amazon UK) (decent little case that would fit well with the motherboard)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  (£48.98 @ Novatech) (excellent seasonic built power supply, very silent and a great value. )
Monitor: LG 22MP55HQ-P 60Hz 22.0" Monitor  (£100.42 @ CCL Computers) (an IPS monitor is well worth it. This one is great bang for the buck)
Mouse: Cooler Master Recon Wired Optical Mouse  (£34.00 @ CCL Computers) (same)
Headphones: Kingston HyperX Cloud Pro Headset  (£57.00 @ Amazon UK) (same)
Total: £940.11
Generated by PCPartPicker 2015-03-11 01:30 GMT+0000
No change here should really affect performance in game in any significant way. It's still a beast of a system packed in a small case. If anything there is you might want to change it's the hard drive from a 1TB to a 2TB barracuda instead. It's up to you and I have no idea how much data you store. Otherwise maybe get an aftermarket heatsink. It's certainly not necessary since you're not overclocking, but might be a nice addition if you care a lot about the noise of your PC under load (the whole system should be very quiet if just web browsing, watching youtube etc...)
https://linustechtips.com/topic/325913-first-pc/#findComment-4426784
Hey guys ive designed this pc that i am thinking about building for my first proper gaming pc, is it a good build and is there anything that you would change?  http://uk.pcpartpicker.com/p/z2M7gs
thanks
-vDemonnnz
What is your budget ?
Do you already have some of the items, as some prices are missing (Windows, Keyboard) ?
https://linustechtips.com/topic/325913-first-pc/#findComment-4426815
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£179.99 @ Amazon UK)
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  (£44.99 @ Amazon UK)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  (£58.99 @ Scan.co.uk)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory  (£97.55 @ CCL Computers)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  (£73.95 @ Amazon UK)
Case: Corsair Vengeance C70 (White) ATX Mid Tower Case  (£92.94 @ Scan.co.uk)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.79 @ Aria PC)
Operating System: Microsoft Windows 8.1 Pro - 64-bit (OEM) (64-bit)
Monitor: BenQ XL2411Z 144Hz 24.0" Monitor  (£208.96 @ Aria PC)
Keyboard: Gigabyte GK-OSMIUM BRN Wired Gaming Keyboard  (£77.36 @ Scan.co.uk)
Mouse: Logitech G502 Wired Optical Mouse  (£46.98 @ Amazon UK)
Headphones: Kingston HyperX Cloud Headset  (£61.34 @ Scan.co.uk)
Total: £1293.94
Generated by PCPartPicker 2015-03-11 02:03 GMT+0000
https://linustechtips.com/topic/325913-first-pc/#findComment-4426972
