Hey im building a new comp.
The specs are as follows:
Kingston ValueRAM DDR3 1600MHz 8GB    ASUS Z97-P, Socket-1150
Gainward GeForce GTX 970 4GB
Fractal Design Define R5 Black
Intel Core i5-4590
Kingston SSDNow V300 120GB 2.5"
Seagate Barracuda® 1TB
Cooler Master G550M, 550W PSU or
Corsair CX 500W PSU
My question is regaring the psu.
Im thinking about buying the cooler master, or will i be fine with the corsair? (its on sale)
OR, should i buy a "stronger" psu, like 650 or something?
Thanks for your time :)
https://linustechtips.com/topic/325700-help-choosing-psu/
evga supernova is a bit too expensive for me :P
The cheapest RELIABLE 500w PSU. So anything form EVGA, Corsair (except the RM series), XFX, Seasonic, Rosewill, Antec, just to name some.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/325700-help-choosing-psu/#findComment-4423996
Alright thanks.
However, will the cx500 be enough even if i at a leter point want to buy another ssd to run in raid 0, and a wirless network card?
https://linustechtips.com/topic/325700-help-choosing-psu/#findComment-4425105
antec or seasonic 4 you - if u had one more corsair product I would add corsair
low = no modular
mid = semi modular
high = full modular
u don't need more then 750-760w but as u wish
@Gresdel
Edited by Benielishackove
When i'm not playing PC games i'm playing with my PC parts  Fans,Pumps,Filters,  :wub:  :wub:  :wub:
https://linustechtips.com/topic/325700-help-choosing-psu/#findComment-4425232
low = no modular
mid = semi modular
high = full modular
@Gresdel
So i hould go for a 750w?
or is the corsair cx500 ok? or should i go for the cooler master 550w?
The cx500 has 38amps on +12V i believe and the cooler master has 42 i think.
https://linustechtips.com/topic/325700-help-choosing-psu/#findComment-4425297
I would go for the corsair and I would get the 600+ w
https://linustechtips.com/topic/325700-help-choosing-psu/#findComment-4425307
Isnt that a bit overkill or?
I really dont know, so please do explain :P
im going like this about 7 year ago I got 500w
now im getting the ax760i you want you mobo to get the best power possible and with no effort and clean if u don't buy an UPS invest in an RX 450-550w even if u don't get SLI
https://linustechtips.com/topic/325700-help-choosing-psu/#findComment-4425393
