So, long story short, a jackass robbed a store and the owner sold me these speakers (for like 10$) 'cause he stole the amplifier.  So now i'd like to buy one and make them work and also, if possible, to use them on my pc. Thank you
p.s. please take note i'm totally noob on this kind of stuff
post-101544-0-16788500-1425814269_thumb.
post-101544-0-22917800-1425814411_thumb.
post-101544-0-94921800-1425814460_thumb.
post-101544-0-84780100-1425814485_thumb.
https://linustechtips.com/topic/324277-i-need-help-finding-an-amp/
-snip
Just look around for absolutely any 5.1 channel digital receiver you can find. See what you can find cheap and don't be afraid of buying second hand. You will be able to hook the speakers up to the receiver with standard speaker wire.
If you want to use it on your pc than make sure it has hdmi input so you can plug it into your motherboard and take advantage of all 5 speakers. I run the same setup on my pc with a 5.1 channel Samsung Receiver and corresponding speaker.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
unfortunately second hand stuff here is not an option. i'd buy a cheap one on amazon but it looks like the ones with hdmi are not cheap. this is what i found http://www.amazon.it/Av2-H388-Amplificatore-Surround-Potenza-Ricavitore/dp/B0068MFIW4/ref=sr_1_2?ie=UTF8&qid=1425817413&sr=8-2and it is in my budget (150 euros)
Specs look great and could well enough handle the job.
Just curious about the one star review. What does it say (can't read Italian here)?
Edit: Doesn't look to have good reviews http://www.amazon.co.uk/product-reviews/B0068MFIW4
Should probably avoid it and continue hunting. I don't know how things are there in Italy but over here some electronics stores sell receivers for decent price so maybe look around there if possible.
Don't buy it it's really bad.
it says there's a buzzing and the audio input is analogic only. thanks for the heads up i'll find something in a store if possible
