Didn't I just post this?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.98 @ OutletPC)
CPU Cooler: Noctua NH-U14S 55.0 CFM CPU Cooler  ($68.98 @ OutletPC)
Motherboard: EVGA Z97 FTW ATX LGA1150 Motherboard  ($159.99 @ Amazon)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory  ($61.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($217.89 @ OutletPC)
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card  ($532.99 @ SuperBiiz)
Case: Fractal Design Define R5 (Black) ATX Mid Tower Case  ($107.99 @ SuperBiiz)
Power Supply: Corsair Professional 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($109.99 @ Newegg)
Monitor: Acer G246HLAbd 60Hz 24.0" Monitor  ($129.99 @ Amazon)
Total: $1776.78
Generated by PCPartPicker 2015-03-07 10:52 EST-0500
https://linustechtips.com/topic/323758-my-first-pc-build/#findComment-4399286
I see you went ahead and added another 290x you might want a 1200w or 1300w though just to be safe and I gave you 1333 ram by accident get the cheapest 1600
2 of these will serve you fine http://pcpartpicker.com/part/lg-monitor-23mp55hqp
https://linustechtips.com/topic/323758-my-first-pc-build/#findComment-4399291
Total: $1776.78
I put in the wrong link, this one should work: http://pcpartpicker.com/user/Nightmare_31/saved/#savedbuild_20999291
https://linustechtips.com/topic/323758-my-first-pc-build/#findComment-4399423
This is excellent however just spending an extra $70 on a WD Black 2TB HDD is useless. No difference between Barracuda's WD Blue's and Blacks. Just get the 2TB Barracuda, will save you $70.
https://linustechtips.com/topic/323758-my-first-pc-build/#findComment-4400948
Swap the psu to the EVGA Supernova G2 750W.
http://pcpartpicker.com/part/evga-power-supply-220g20750xr
And get the cheaper version of Windows 8.1
http://pcpartpicker.com/part/microsoft-os-wn700615
Also as mentioned above, WD Black drives are not worth the extra money.
https://linustechtips.com/topic/323758-my-first-pc-build/#findComment-4401825
