Recently I have moved and the house we had moved to had built in Ethernet in all the walls! When I went to hook it up to my pc I am running into some issues. I am getting the error 651(the modem has reported an error.I have tried the Ethernet built into my motherboard and a dedicated Ethernet card. Still I have the same issue. I have the cord that is connected to my pc in one of the 1-5 slots (and have switched them around). and still get this error. Ethernet works fine for my cable box but not on my pc. Thanks for the help  :)
https://linustechtips.com/topic/323443-cannot-connect-using-ethernet/
have you checked the other end of the cable? :P
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
