Hello, I am putting together a workstation pc for my father. He does a lot of autocad and needs something that will last him. He is tired of his old pc fucking up all the time. I put together this http://pcpartpicker.com/p/tCxkyc. I know its not even close to perfect and am coming to you guys for more ideas.
Not sure if the quadros will run three monitors... needs to run three monitors.
https://linustechtips.com/topic/323226-2000-build-ideas/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($369.88 @ OutletPC)
CPU Cooler: be quiet! Shadow Rock 2 87.0 CFM Rifle Bearing CPU Cooler ($34.99 @ NCIX US)
Motherboard: MSI X99S SLI Plus ATX LGA2011-3 Motherboard ($166.98 @ Newegg)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2133 Memory ($106.98 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($88.98 @ OutletPC)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($124.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card (2-Way SLI) ($552.98 @ Newegg)
Case: Corsair 750D ATX Full Tower Case ($119.99 @ Micro Center)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.99 @ NCIX US)
Total: $2300.62
Generated by PCPartPicker 2015-03-06 14:56 EST-0500
no way you are going to run 3 monitors of a a single quadro
whoa there. little over budget.
https://linustechtips.com/topic/323226-2000-build-ideas/#findComment-4393296
The K4200 will drive up to 4 displays using DP 1.2.
I would suggest going X99. It will provide much better performance in this application. A larger ssd will really help. If the budget could take it, I would suggest going even larger. If you are not familiar with XFX psu, they are essentially re-branded Seasonic models.
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.98 @ OutletPC)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard  ($249.99 @ B&H)
Memory: Crucial 16GB (4 x 4GB) DDR4-2133 Memory  ($160.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($119.95 @ OutletPC)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Best Buy)
Video Card: PNY Quadro K4200 4GB Video Card  ($760.99 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($66.98 @ Newegg)
Total: $1977.72
Generated by PCPartPicker 2015-03-06 16:45 EST-0500
https://linustechtips.com/topic/323226-2000-build-ideas/#findComment-4393500
