600$ Gaming PC Help!
Go to solution Solved by Matriox,
How does this look: http://ca.pcpartpicker.com/p/krvmK8
This is the cheapest new r9 270 I could find. Im 18$ over budget but my friend said he'd be fine with that.
Looks good to me and should preform much better than the 260x he won't regret it :D
Hey everybody, my buddy asked me to make him a 600$ (CAD) gaming pc to play games like GTA V, CS:GO, Gmod, Arma 2 and Minecraft. So far I have come up with this: http://ca.pcpartpicker.com/p/LpHrhMDoes anyone have any recommendations? Thanks! (Please read list below)
  • Processor: I chose the intel i3 4160 as my processor because of its great performance and low price point. It actually costs the same as some lower end i3's right now. I took the intel over amd's FX series because of its great upgrade path compared to the dead am3+ socket.
  • Motherboard: I chose the MSI CSM-H87M-G43 motherboard for its 4 ram slots that support 1600mhz+ ram, having a PCI-E 3.0 slot instead of a 2.0 and having a onboard usb 3.0 header. I wanted 4 ram slots so I could upgrade to a higher capacity and the usb 3.0 since my case has one.
  • Ram: I chose the G.Skill Sniper ram because it is the cheapest 8GB 1600mhz set available while still being very reliable and having a awesome and functional heat spreader.
  • Storage: I chose the Seagate Barracuda 1TB because it is the cheapest 1TB available while still coming from a very reliable manufacturer.
  • Graphics: I chose the VisionTek R7 260x as my gpu for its very efficient cooler, overclockability and cool look.
  • Case: I chose the Fractal Design Core 1000 as my case because it is considered one of the best budget cases on the market. It also has a understated look, high airflow design and usb 3.0 support.
  • Power supply: I chose the EVGA 500W power supply because it is very reliable, has 80+ certification and all the cables are braided.
  • Bluetooth adapter: I chose a ASUS bluetooth adapter because my friend has a bluetooth headset and needs a cheap adapter with good range.
  • Wi-Fi adapter: I chose a TP-Link Wi-Fi adapter because it is cheap and my friend is close to a range extender, so an antenna was not needed.
https://linustechtips.com/topic/322719-600-gaming-pc-help/
I'd try to fit a 270 at least.. I've seen $300 builds with 260x's but if you really want your money's worth try ebay. They have fairly used cards for around $120 LIKE A 280! which will easily max 1080p
CPU¤Core i5 5675c ¤Cooler¤Ghetto water loop(Cheap tubing & block from amazon)¤GPU1¤Sapphire R9 290x Tri-x¤MOBO¤Asrock H97m Anniversary ¤RAM¤8GB DDR3 1866Mhz¤Storage¤2Tb SSHD & 320Gb HDD¤Case¤Cougar Spike Mini ITX case¤PowerSupply¤500w EVGA 80 plus¤
https://linustechtips.com/topic/322719-600-gaming-pc-help/#findComment-4386319
Good idea, Ill see what I can find. Btw is it worth is spending extra for a "x" card or can i just overclock a non x card to match?
https://linustechtips.com/topic/322719-600-gaming-pc-help/#findComment-4386338
from the 270 to the 270x you can definitely overclock and match. And honestly almost all amd cards are like that for example the 290 lol it scores like 2 frames off the 290x in nearly all benchmarks so my advice is try for a x but if not a non x is just fine and can sometimes be unlocked to an x  :D
https://linustechtips.com/topic/322719-600-gaming-pc-help/#findComment-4386368
https://linustechtips.com/topic/322719-600-gaming-pc-help/#findComment-4386464
https://linustechtips.com/topic/322719-600-gaming-pc-help/#findComment-4386626
