Sometimes when I'm using the laptop it freezes and goes black. I can press CTRL+ALT+DEL and it works fine, but when I try to open Task Manager I am prompted with the same black screen.
I opened the Event manager and saw multiple errors, but I think this is the reason it crashes.
Log file down below
Log Name:      Application
Source:        Microsoft-Windows-EapHost
Date:          02-03-2015 14:20:30
Event ID:      2002
Task Category: Peer
Level:         Error
Keywords:      Registry
User:          SYSTEM
Computer:      XXXXXXXXXXXXX
Description:
Skipping: Eap method DLL path validation failed. Error: typeId=43, authorId=9, vendorId=0, vendorType=0
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-EapHost" Guid="{6EB8DB94-FE96-443F-A366-5FE0CEE7FB1C}" />
    <EventID>2002</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>2</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000001</Keywords>
    <TimeCreated SystemTime="2015-03-02T13:20:30.108965700Z" />
    <EventRecordID>79564</EventRecordID>
    <Correlation />
    <Execution ProcessID="3264" ThreadID="8592" />
    <Channel>Application</Channel>
    <Computer>IT-02218.rtx.loc</Computer>
    <Security UserID="S-1-5-18" />
  </System>
  <EventData>
    <Data Name="Key Name">Eap method DLL path</Data>
    <Data Name="TypeId">43</Data>
    <Data Name="AuthorId">9</Data>
    <Data Name="VendorId">0</Data>
    <Data Name="VendorType">0</Data>
  </EventData>
</Event>
https://linustechtips.com/topic/322265-pc-stops-responding-not-bsod/
It has got something to do with a broken and corrupted registry file.
Try using some sort of registry fixer.
Also use dll file fixer.
I assume these two softwares can help you solve your problem.
If it still fails .,.,. try a new copy of windows (fresh installation)
Thanks
