Welp, I am about to sell my computer when suddenly boom
"The AMD CrossFIreX internal bridge interconnects linking your graphics cards together are not properly attached. Both bridge interconnections must be attached"
I need help asap as I am selling this computer tomorrow at 7pm. It worked before and I don't know why it doesn't now. I tried re installing AMD catalyst and resetting the CMOS and adjusting the bridge. I don't have another bridge though.
https://linustechtips.com/topic/320213-gpu-crossfire-cable-dead/
Run down to the nearest Microcenter or Fry's if you can and pick one up. OR go NES on that shit and try blowing on the connections.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/320213-gpu-crossfire-cable-dead/#findComment-4352131
I live in Canada and the nearest computer store is like 7km away.
7 or 70? If only 7, then that's no very far... My nearest Fry's is 30km and my nearest Microcenter is about 110km away.
https://linustechtips.com/topic/320213-gpu-crossfire-cable-dead/#findComment-4352149
your complaining about a 15 minute bike? Sure the weather right now isn't great but still.
https://linustechtips.com/topic/320213-gpu-crossfire-cable-dead/#findComment-4352154
Try removing the cables from the two GPU's and plug them back in and reverse the, crossfire cable and see if that works (
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/320213-gpu-crossfire-cable-dead/#findComment-4352163
