Open-back headphone help?
Solved by Pomfinator,
500X and 700X are cheaper and sound very similar. I say go for the 700X instead, @ShearMe would tell you to get the 500X since he can't tell the difference. ![]()
You could also look at the Sennheiser 558, the K7XX's which are still on Massdrop, DT990, etc. It would also help if you could tell us what kind of sound signature you're looking for.
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies0 -
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
7
5
ken43 ·
Posted in Troubleshooting5 -
9
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
