HELP WITH A SMITE LAN BOX
By
Daniel91
in Graphics Cards
in Graphics Cards
Solved by Daniel91,
An R7 260X could handle those games easy at 1080p, don't know about 1440p though but it should run fine. A 970 would be overkill. If he is looking to build an on the go LAN box I would go with a Pentium G, but if he has the cash then go for the i5 and 970, you never know what he will use the LAN box for in a few years.
k thank you
Jayraj ·
Posted in Power Supplies0 -
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
6
5
ken43 ·
Posted in Troubleshooting5 -
8
thedood2k ·
Posted in Power Supplies3 -
3
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
