PCPartPicker part list: http://pcpartpicker.com/p/WYGmJx
Price breakdown by merchant: http://pcpartpicker.com/p/WYGmJx/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($116.98 @ Newegg)
or
Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard  ($119.89 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2133 Memory  ($129.99 @ Newegg)
Storage: PNY XLR8 120GB 2.5" Solid State Drive  ($64.99 @ Micro Center)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($339.00 @ NCIX US)
Case: Corsair 760T White ATX Full Tower Case  ($159.99 @ NCIX US)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ NCIX US)
Total: $1275.92
Generated by PCPartPicker 2015-02-24 13:41 EST-0500
The focus on my build was the Corsair 760T case in Arctic white. It's the best looking case IMO. When I started planning this build I was wanting the build to be blue, but I find my self loving the way the Krait Edition motherboard looks so that is still up in the air.
My location is the US. I plan to run triple displays (two monitors and a 42" TV) I do alot of multi tasking on my pc, often playing games on one monitor surfing on another while playing media of some type on my TV. I'm one of those tab fiends with anywhere from  10-25 tabs open in each browser window, and 2 or 3 windows open at a time. As far as gaming goes I typically play LoL, I have Skyrim, but playing on my current PC is more frustrating than fun so I haven't touched the game since I installed it. I'm also planning on running emulators on my pc, as well as open source games like Mugen, StepMania, Osu and the like. I want this to be the only PC I will need , if possible, for the next 10 years or so. I've only bought prebuilt PC's before with my current rig being a gateway DX series I bought 3 years ago, it has a Core i3 530, a 350watt psu, 3 Hard drives (1 1TB, 2 500GB) and an EVGA GTX 550Ti, however with that graphics card I had to disconnect one of my hard drives and my optical drive to power the 550. I'm trying to keep the build under $1500 USD, and would like to avoid recycling parts from my gateway outside the HDD as I plan to just give it to my little brother.
All feedback is welcomed
***UPDATE***
So, as mentioned before, I wasn't sure what motherboard I wanted to go with, however since posting this, I have looked through every Z97 Motherboard available, as well as a couple of Z87s. and after many hours spent searching, I decided on an ASUS Z97-AR. I have received both the CPU (4790k) and the Z97-AR, I must say, the Z97-AR Motherboard looks amazing, really happy with it so far.
Intel Core i7 4790k
ASUS Z97-AR
Back of Motherboard box
Motherboard
CPU and Motherboard
https://linustechtips.com/topic/317247-first-build/
Nice Build, I would go with an Asus Board. Also if you are doing a 3 monitor setup including a 42 inch tv, than I recommend looking at a SLI or Cross Fire solution on your GPUs. If you have questions you can post on the forum or PM me for my opinions.
FYI: FOLLOW YOUR OWN THREAD @MrJBravo
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/317247-first-build/#findComment-4311741
I will question some of your choices. First, you really can't expect a PC to last 10 years. GPUs have a lifetime of about 2~3 years, which can extend to 5~6 if you are willing to lower settings. The CPU has around 5 years of life as well. Things become obsolete way too fast.
That said, I question some of your choices:
  1. The CPU Cooler. My suggestion is the Raijintek Triton. It doesn't show on partpicker, but Newegg has them for 99$. It has a much better performance, and it's also one of the best looking CPU coolers out there. In fact, you could even use it for custom loop, if you ever feel the desire to have one, so that's one part that you could re-use in a future build.
  2. The CPU itself. It seems that you wouldn't really take advantage of a 4790k; the 4690k would do just as fine. By the time games will actually require all those threads, the CPU would be too weak anyway.
  3. The GPU brand. The Asus Strix, for the price, is currently the best choice. It has the 0db feature, it's one of the quietest under load, and it doesn't have that CPU cooler design problem. I mean, nothing wrong with EVGA, but they really screwed up the 970 series.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/317247-first-build/#findComment-4311841
Thanks, I've really put a lot of thought into it, and I originally intended to go with an ASUS board but I really wanted a blue build, and ASUS doesn't have any blue boards that I could find
https://linustechtips.com/topic/317247-first-build/#findComment-4311858
Yea I just like ASUS and would compromise. @Imakuni , He has a nice cooler and build, an i7 is perfect and worth it. Those monitor are going to push on the applications and he needs that kind of power.
Chase B
https://linustechtips.com/topic/317247-first-build/#findComment-4311883
@MrJBravo , I PMed you. Make sure to check the message icon near the notifications tab at the top of the page.
Chase B
https://linustechtips.com/topic/317247-first-build/#findComment-4311897
Yup, his cooler is nice. But he can get a better product for cheaper. I needed to point that out.
And I really don't see how is the i7 worth it. Multimonitor setups really don't push the CPU. If he said "I'll be streaming" or "I wanna video render", then by all means go for it. But from what he described, it seems he wouldn't benefit that much from the i7.
https://linustechtips.com/topic/317247-first-build/#findComment-4311934
When an application has to scale and then that application has to run at that, it can cause cpu pushing. Not much but some. If his budget allows it, then he should do it. I still prefer any corsair cooler
Chase B
https://linustechtips.com/topic/317247-first-build/#findComment-4311950
Hey, if you prefer Branding over actual performance, be my guest.
https://linustechtips.com/topic/317247-first-build/#findComment-4311974
1. I chose the CPU cooler more because of the included blue rings so it was more aesthetics than anything
2. As far as the CPU, as mentioned I do own alot of media files, and the part i left out (sorry) is I plan to start doing some video editing, nothing too intensive but more just wanted the breathing room, the 4690k was the original plan, but then I got my tax refund and was like YOLO
3. I went with EVGA  because of the blue accents to it, i wanted a 970 with blue on it and it came down to EVGA or MSI, EVGA was I think $30 less
https://linustechtips.com/topic/317247-first-build/#findComment-4312083
  1. And? The Raijintek Triton has blue water. Or red. Or green. Or even crystal clear. You can match your build in any way you'd like.
  2. Oh... ok.
  3. I guess if you want a blue accent, the Gigabyte G1 Gaming would be awesome for you. Best OC, temps, and has a backplate, as well as the coveted blue LED.
https://linustechtips.com/topic/317247-first-build/#findComment-4312133
  • 1 month later...
