Hi guys.
I am stuck in choosing which case I should go for and whether or not I should go down the ATX or the MicroATX route. I have narrowed it down to 3 cases, 1 in the Micro ATX form factor and the other 2 in the ATX.
Micro ATX
Corsair Air 240 - http://uk.pcpartpicker.com/part/corsair-case-cc9011069ww
ATX
Corsair 760t Full Tower- http://uk.pcpartpicker.com/part/corsair-case-760twhite
Corsair Air 540 - http://uk.pcpartpicker.com/part/corsair-case-air540
I am looking for help in choosing which one would be best to go for with the system I will be assembling. Which one would you guys recommend?
The system I will be building is listed below ATX Form Factor
PCPartPicker part list: http://uk.pcpartpicker.com/p/6VnmJx
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£268.97 @ Ebuyer)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  (£74.72 @ CCL Computers)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  (£111.56 @ Scan.co.uk)
Memory: Kingston Savage 8GB (2 x 4GB) DDR3-2400 Memory  (£50.90 @ Overclockers.co.uk)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£79.48 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£39.95 @ CCL Computers)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card  (£453.94 @ Amazon UK)
Case: Corsair 760T White ATX Full Tower Case  (£149.98 @ Amazon UK)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£90.11 @ Amazon UK)
Total: £1319.61
Micro ATX
PCPartPicker part list: http://uk.pcpartpicker.com/p/TFjYqs
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  (£84.99 @ Amazon UK)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard  (£107.96 @ Scan.co.uk)
Case: Corsair Air 240 MicroATX Mid Tower Case  (£74.34 @ Scan.co.uk)
Total: £1171.16
https://linustechtips.com/topic/316688-which-case-to-go-for/
Are you going to be moving it much or will it be in one place for it's life?
It won't move much as I will be placing it on my carpet as I don't have too much room for it anywhere else in my room, and because it will be on my carpet I was kind of leaning towards the Corsair 760t due to the fact it has feet on the bottom which raise the body of the case of the ground a few inches.
https://linustechtips.com/topic/316688-which-case-to-go-for/#findComment-4304670
Oh, ok, yeah. Then i'd get the ATX build. mATX is good for moving it around a lot or tight spaces. If you have the sapce, the 760t is a great choice.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/316688-which-case-to-go-for/#findComment-4304763
I guess I could buy a small coffee table and put the PC on that if it came down to it so I then won't get a lot of dust inside the case.
https://linustechtips.com/topic/316688-which-case-to-go-for/#findComment-4304779
As long as you clean it every now and then, you'll have no issues.
https://linustechtips.com/topic/316688-which-case-to-go-for/#findComment-4304813
I like mATX and mITX but since mATX normally doesn't cost more I think you should go for the 240. I've been look at it for a while now and I would use that noctua cooler with the 2 140mm fans for low profile (don't remember the name). Pcpp says it doesn't fit in the 240 but it does with just 1 fan.
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
https://linustechtips.com/topic/316688-which-case-to-go-for/#findComment-4305010
I would go matx and ft03 as case
https://linustechtips.com/topic/316688-which-case-to-go-for/#findComment-4305026
I think I will just go with the Corsair 760t.
https://linustechtips.com/topic/316688-which-case-to-go-for/#findComment-4305377
