Will these things fit?
Go to solution Solved by IP man,
Yeah they should work.
In the midst of choosing a blue-coated RAM, I got a choice between getting 2 separate Kingston HyperX Fury at 1866Mhz or getting Gskill Ares also at 1866Mhz. Gskill is quite a cheaper price by around 5-6USD. I'll ask if it will fit on these specs:
Mobo: MSI A78-G41 PCMATE
CPU Cooler: Hyper T4
no need for other parts to be included.. I just want to know if getting Gskill Ares will fit since it has a bit bulge on top
https://linustechtips.com/topic/316601-will-these-things-fit/
