Hi,
Here's what's happening. I have 8gb of RAM installed. My Task manager displays it correctly but when I start google chrome+any other game my RAM jumps to around 3.47gb used it's aruong 40% according to Task Manager, However I suddenly get this message that my computer is running out of memory and my game automatically closes and google chrome crashes. I usually encounter this issue when I was using my old PC which has only 4gb of RAM however this PC that I'm using has 8GB. Is there some kind of memory leak? Help me guys
Mobo: Gigabyte G1 Sniper M3/ Processor: Intel 3570k @ 4.5Ghz / Memory: 2x4 GB DDR3 1866Mhz Corsair Vengeance
VGA: Powercolor 7870 Myst SSD: 128GB Crucial M4  / HDD: WD Green 2TB
Power Supply: Seasonic S12 620w Case: Fractal Design Define Mini / Cooling: Corsair H80
https://linustechtips.com/topic/31656-ram-usage-help/
damnnn... ahahaha I hate reinstalling windows..  <_<
https://linustechtips.com/topic/31656-ram-usage-help/#findComment-404663
Maybe a windows repair will fix the problem. If not, you got a little chance that a BIOS update (and/or other driver updates, although that is highly unexpectable) will help. If a windows repair does not work, the best option is indeed to reïnstall windows.
Wi RoZ
https://linustechtips.com/topic/31656-ram-usage-help/#findComment-404713
hmm BIOS update seems kinda viable. I've been wanting to update/downgrade it since I shift to F9 Bios my up and down inside UEFI got inverted. lol
https://linustechtips.com/topic/31656-ram-usage-help/#findComment-404724
