I'm kind of a newbie at this whole PC thing and I need some help with my first build I will be doing within the next month. I greatly appreciate any kind of suggestion or help with this, as I've never done it before and you guys(and girls) are experts. Here is my build.
CPU- AMD Athlon 760k
Graphics Card- EVGA GTX 960 SSC
MB- Gigabyte A88X AM2 Socket
RAM- Kingston HyperX Fury 8GB(2x4GB)
SSD- Samsung 850 EVO 250 GB SSD
HDD- WD Green 2TB
Power Supply- Corsair CX430M
Case- Corsair SPEC-01
All running Windows 8.1
I thank you in advance for any and all help. I really am just looking for some assurance that these parts all work together and will not crash and burn, along with some tips to keep it running smoothly for a long time. Please and thank you.
CPU:Intel i5 4690k GPU:EVGA GTX 970 SSC Motherboard:MSI Z97 G45 RAM:Kingston HyperX Fury 8GB PSU:Corsair CX600M SSD:Crucial MX100 256GB HDD:Seagate 3TB Case:Corsair SPEC-02
https://linustechtips.com/topic/316280-please-help/
HDD- WD Green 2TB
looks good to me...
Personally I'd swap the athlon for a g3258 because of the better upgrade path on LGA 1150 and get a 280 over the 960 because 3gb VRAM and it's a bit faster
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/316280-please-help/#findComment-4298639
HDD- WD Green 2TB
if you want try pcpartpicker.com tells you if it is compatible and you can find the link of the website you want to buy it off of.Whats your budget we can help if we know your budget?
Hi friend.Who are you?
https://linustechtips.com/topic/316280-please-help/#findComment-4298673
Probably under $1500 US dollars and I will eventually be using a 4k monitor
https://linustechtips.com/topic/316280-please-help/#findComment-4298690
You can get way more powerful PC for that kind of money :) What is your aim ? Gaming, editing, both ?
I kind of wanna some some gaming and a little editing just for fun maybe and browsing with some you tube vids but I want it to be powerful
https://linustechtips.com/topic/316280-please-help/#findComment-4298760
k
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($215.00 @ Amazon)
Motherboard: Asus Z97-E ATX LGA1150 Motherboard  ($99.99 @ SuperBiiz)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($54.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($118.98 @ OutletPC)
Storage: Western Digital WD SE 2TB 3.5" 7200RPM Internal Hard Drive  ($124.99 @ B&H)
Video Card: Asus Radeon R9 290 4GB DirectCU II Video Card  ($293.99 @ SuperBiiz)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($34.98 @ NCIX US)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.88 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.75 @ OutletPC)
Monitor: Acer GN246HL 144Hz 24.0" Monitor  ($236.99 @ SuperBiiz)
Total: $1327.54
Generated by PCPartPicker 2015-02-23 20:38 EST-0500
now you have 67.46 for peripherals and if you want a CPU cooler .This video card can handle 4K,but if you want another GFX card then you need a more powerful power supply but you can get a 4k moniter instead if you want.Also overclocking ready for that i5 on this video Linus overclocks the G3258 to 4.4GHZ with the stock CPU cooler so you could do the same.
https://linustechtips.com/topic/316280-please-help/#findComment-4298827
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($319.73 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.98 @ OutletPC)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($137.99 @ SuperBiiz)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($62.99 @ Amazon)
Storage: Western Digital WD Green 2TB 3.5" 5400RPM Internal Hard Drive  ($69.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($579.79 @ Amazon)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($43.99 @ Newegg)
Total: $1423.32
Generated by PCPartPicker 2015-02-23 20:49 EST-0500
This would be going all out only for tower. Dunno if you already have peripherals and stuff like that, if not probably step it down to 4690K and GTX970/R9 290X
My modded Air 540 build
https://linustechtips.com/topic/316280-please-help/#findComment-4298901
Total: $1423.32
Darn you beat me for almost the same price
https://linustechtips.com/topic/316280-please-help/#findComment-4298965
Ya I have a monitor and speakers on hand ready to use and thank you so much for all your help, I really appreciate it.
https://linustechtips.com/topic/316280-please-help/#findComment-4299049
