My cousin was looking into buying a Mac Pro, but then he asked me if I could build him one that is better. I said yes, and mine will be WAY better and also WAY cheaper to. So I just want to know if all these parts are compatible with OSX, and if you think this works as a Mac Pro, "Killer".
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.88 @ OutletPC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($99.75 @ OutletPC)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($204.98 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card (2-Way SLI)  ($329.00 @ NCIX US)
Case: Corsair Air 240 MicroATX Mid Tower Case  ($74.99 @ NCIX US)
Total: $2220.55
Generated by PCPartPicker 2015-02-23 17:12 EST-0500
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/
why dual 970s? A 980 would probably be better. Then you could even sli 980s in the future if you want.
Cheaper and better performance for the money, this is a productivity Mac, not a gaming machine
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/#findComment-4297469
you will get some shit for saying a 980 is better than 2 x 970's however i agree that he should get a 980 so he could add another in the future
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/#findComment-4297475
Yes I know. I for one would much rather get a 980 then another in the future instead of 2 970s outright
Yea same i agree then you can add more 980's
1
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/#findComment-4297486
If it's not a gaming machine, why bother getting gaming grade GPUs in the first place? Why not Quadros? At least the Mac has FirePros, so it's workstation-grade as opposed to gaming-grade.
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/#findComment-4297517
Aren't quadros like $5000?
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/#findComment-4298479
How good or poorly is the nvidia cards support in OSX?
Is tonymacx86 site not useful for compatibility questions? Or is that place junk?
They're the best, as they're super specialized. I do a lot of lurking there.
But they take a while to get back to you as they are a bit of a smaller community.
I love it there. It's what LTT isn't; helpful
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/#findComment-4298936
thought they were good, I ran into that site couple of years ago, just didn't really have the cash or patience to have used it.
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/#findComment-4299390
Great pc but not mac pro killer. Think Xeon and firepro/quadro
i7-5930K@4.7Ghz | Asus X99-E-WS/USB 3.1 | Corsair Vengance 32GB DDR4@2666Mhz | Duo Gigabyte GTX 1080 Xtreme Gaming | Samsung 950Pro 512GB | LSI 9260-8i RAID Card | 6x 1TB Samsung 850 Pro (RAID5) | Corsair AX1200i |  Fractal Design Defiine R5 Black | MetaDot DasKeyboard4 Professional | Logitech G900 | Windows 10 Pro 64-bit | Asus PG348Q
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/#findComment-4310089
http://pcpartpicker.com/parts/video-card/#c=216,218,217,219,155,220&sort=a8
@ANewFace,
It is actually difficult to do much better than the Mac Pro. One issue with DIY builds is the ECC memory used by the Mac Pro.
Why does the build have two ssd?
The Mac Pro has dual band a/b/g/n/ac WiFi & Bluetooth 4.0; Thunderbolt ports; and dual gigabit Ethernet ports.
https://linustechtips.com/topic/316193-my-mac-pro-killer-help/#findComment-4310202
