TP-Link never failed me...
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704133
For more options, decide if you want Dual Band (5+2.4Ghz) or only 2.4Ghz, what speeds do you want to achieve. Also very important, depending on how far you are from the access point you should choose an adequate card.
Personally I wouldn't pay more than $50 USD for a wireless card.
https://linustechtips.com/topic/316031-wifi-card/#findComment-4295031
You don't want a USB WiFi dongle if you care about range or signal strength.
You want a PCIE WiFI card that supports dual band 5GHz N series at the least. They're around $20 and awesome. Tri band is kind of  waste of time for all but the most congested condominiums.
https://linustechtips.com/topic/316031-wifi-card/#findComment-4295060
