I can't see the link.... What's your budget?
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/315814-build-help-please/#findComment-4291705
I'd assume it's in USD so:
PCPartPicker part list: http://pcpartpicker.com/p/whD6xr
Price breakdown by merchant: http://pcpartpicker.com/p/whD6xr/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($99.75 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($100.98 @ Newegg)
Memory: PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory  ($112.72 @ Amazon)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($50.78 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card  ($549.00 @ NCIX US)
Case: Corsair 760T White ATX Full Tower Case  ($159.99 @ NCIX US)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($48.99 @ SuperBiiz)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.98 @ OutletPC)
Total: $1465.07
Generated by PCPartPicker 2015-02-23 00:28 EST-0500
If something's wrong let me know.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/315814-build-help-please/#findComment-4291752
For me, nothing's wrong with the build. Adding SSD would be better.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/315814-build-help-please/#findComment-4291754
Take a look at the Asus Z97-E motherboard. Very similar features to the Z97-A at a lower cost.
XFX P1-550B-BEFX, Antec HCG-620M, or SeaSonic SSR-550RM would be better psu choices.
Consider an air tower cpu cooler like the Cooler Master Hyper 212 EVO or Noctua NH-U12S.
If you can fit it into the budget add a 120+GB ssd.
https://linustechtips.com/topic/315814-build-help-please/#findComment-4291818
So this is what you recommend to put on a PC that is going to be overclocked and pretty much being put to its limits. I'm mostly going to be gaming in 1080p not really 4k.
Well, I see you've got $1500 for the budget.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/315814-build-help-please/#findComment-4291862
If you're mainly gonna be gaming then get the i5 - They over-clock the same and the hyperthreading of the i7 doesn't do much for games as they are mainly a single core process anyway.
Personally I'd go for a high-end air cooler over a AIO liquid cooler. Performance is the same and air coolers are cheaper and quieter not to mention fewer points of failure. I'd opt for something like the noctua NH-D15. The money saved from going i5 instead of i7 and air cooler instead of AIO liquid can get you a pretty nice SSD for the OS which will make a huge difference!
https://linustechtips.com/topic/315814-build-help-please/#findComment-4294107
Good build, but you should really try to add an SSD given you have such nice hardware in that
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/315814-build-help-please/#findComment-4294791
Total: $1465.07
This is a solid build for your budget except I would go for a different PSU.
If you REALLY wanted to save money there are a couple things you could change.
-You could swap the CPU to a i5-4690k. There is very little difference between an 4690k vs 4790k for gaming.
-You could go with 8 gigs of ram instead of 16gb. Again there is no difference when it comes to gaming.
-You could go with an Evo212 cooler and still get a decent OC.
-You could go with a gtx 970 instead of a 980, and still have very decent performance especially if your only on 1080p.
That being said, this build still fits well within your budget and gives you more headroom if you wanted to do some streaming/rendering/editing.
https://linustechtips.com/topic/315814-build-help-please/#findComment-4295421
Even better. I'm not going to be streaming or recording. Just straight gaming
https://linustechtips.com/topic/315814-build-help-please/#findComment-4295887
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
CPU Cooler: Phanteks PH-TC14PE_BL 78.1 CFM CPU Cooler  ($79.99 @ Newegg)
Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard  ($119.89 @ SuperBiiz)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($104.99 @ Adorama)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($338.99 @ NCIX US)
Case: NZXT H440 (Blue/Black) ATX Mid Tower Case  ($119.99 @ NZXT)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Micro Center)
Total: $1184.70
Generated by PCPartPicker 2015-02-23 14:17 EST-0500
https://linustechtips.com/topic/315814-build-help-please/#findComment-4295967
