My configuration:
3570K 3.4GHz
Asrock z77 Extreme 4
Seasonic 760W Platinum
G.Skill 2x4GB 1600Mhz
Lian Li K62
Alright so, I have 2 Gigabyte R9 280X which I plan on selling one of them. For the sake of this post, I will call them card A and card B. During the course of my problems, I did not crossfire them. Only one card was in my rig at a time.
So card B started having problems.
- My screen would "glitch"
- I saw random pixels on my screen flashing
- My screen would completely freeze and the "Display driver stopped responding and has recovered" notification would appear
- Eventually computer would not power on properly. After the bios screen, the screen would turn black with all mouse and keyboard unresponsive
I switched out card B for card A, and everything was smoothe. So I thought there was something definitely wrong with card B. I filed a RMA request and had Gigabyte repair my card. I noticed that they did not tell me what the problem was, or what they fixed. Is this normal?
Two weeks later I received card B from Gigabyte. I install card B into my main rig, and behold, the same problem still persist (computer would freeze at a black screen upon bootup). I thought that there's no way Gigabyte could have ignored something like this so easily. I then realized that I've been using the top PCI slot for my cards all this time, and that the problem could have been my motherboard. So I installed card B in the second PCI slot this time and ran 3D mark, and played some games. I've noticed that my card seems OK. I didn't see any of the problems from before. But why did card A not have any problems in the first PCI slot? Could my motherboard be faulty? Thanks!
https://linustechtips.com/topic/315745-help-me-diagnose-my-gpu/
First, ensure you aren't overclocking your B card. Then set power limit to +20% on MSI afterburner for the B card and turn down the clock speed by 10mhz. Benchmark using UNIGINE HEAVEN to see stability. Keep turning down the clock speed until your system is stable.
https://linustechtips.com/topic/315745-help-me-diagnose-my-gpu/#findComment-4292432
just wondering matey did you get card A in the same slot as Card B????
edit: ok I'm stupid didn't see that part.
hmm this is kinda weird. card A worked fine on the first slot and card B just moans like a fucker?
I'm not sure but I don't think your motherboard is faulty if Card A worked fine.
just wondering if you can try to xfire them.
 card A first pci e lane and card B to the next pci-e 3.0 lane.
Live your life like a dream.
https://linustechtips.com/topic/315745-help-me-diagnose-my-gpu/#findComment-4293768
