I am trying to look for cases with similar form factor to the Ncase M1 (of course a bit larger), or something along that size. Please note that the case must take full sized graphics cards (GTX 650ti), and hopefully ATX PSUs (I can always get an SFX).
This seems like a hard task as all the micro atx cases I seem to find are all too big. Why not go with ITX? Well because I already have the system, I am just looking to upgrade the case.
So far I have found
- Silverstone SG09, SG10, SG01, SG02
- Bitfenix Colossus
https://linustechtips.com/topic/315407-small-micro-atx-cases/
I get your point, you're looking to Cases with PSU inside to save space... Sadly I only know the cases list of one brand :(. In Win...
The BK644 is smaller than the colossus M and SG09. Tho SFX PSU and IDK if you'll like it.
I'd even suggest even smaller cases if you didn't buy the GPU yet.
Mmm the BK644 is still taller than both the colossus M and te SG09 though. Which other case are you suggesting.
https://linustechtips.com/topic/315407-small-micro-atx-cases/#findComment-4286635
Well... the other way I meant if you didn't get the GPU is... getting an LP GTX 750ti and a LP case... those are way smaller but usually deeper to keep 5,25" bays :(
In win (due to what I told about myself before :/) has some, uses TFX PSU (still, you can find new TFX PSUs easily)
:/ Unfortunately I already have  the system, I am just changing the case to make it more HTPC like.
https://linustechtips.com/topic/315407-small-micro-atx-cases/#findComment-4286881
Silverstone PS07 & TJ08-E are my vote, due to good cooling and being compact, as well as supporting ATX PSUs (Getting a silverstone strider unit would be best though)
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/315407-small-micro-atx-cases/#findComment-4286980
