I have returned with more questions 2 in particular
1. Are all the parts in this build going to work?
2. Any green led case fans to really show off the build would be nice any recommendations?
3. Am i paying way to much for what i want to play and what i play currently?
http://pcpartpicker.com/user/Fringedabyss97/saved/#savedbuild_1955440
Im also thinking Future here so im not getting dual 970s
The games I usually play are LOL, skyrim, WOW-WOD, Battlefield 4. I want to get into Metro Last light, Grid, Farcry, Shadow of Mordor and More.
Thanks for the help (let me know if link does not work)
https://linustechtips.com/topic/314789-my-first-pc-build/
They will work, yes.
The PSU is very overkill. I'd get an EVGA Supernova 650W PSU. Also, get a 256GB MX100 instead of the 730 and a 1TB WD Caviar Blue instead of the Caviar Black.I know there are green BitFenix Spectre Pro fans.
https://linustechtips.com/topic/314789-my-first-pc-build/#findComment-4279155
Could go with a slightly cheaper case, and PSU. Also, i'd recommend getting a decent air cooler, like the Noctua NH-D15, or NH-D14. It'll be quieter and perform slightly better, and is slightly cheaper. Would be ideal to get some lower profile ram to fit one of those in though.
Aside from that, not bad.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/314789-my-first-pc-build/#findComment-4279198
That looks good, 750 watts is good since you might go with a SLI config later on.
But if you wont go SLI, 750 watts is overkill.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/314789-my-first-pc-build/#findComment-4279223
I really want liquid cooling i know its not very efficient but i looks cool not really worried about price.
is the NZXT Kraken a good AIO i like the green led on the CPU block?
The X61 is a great AIO.
Bitfenix do a lot of LED fans. The Spectre Pro are pretty decent.
I would go with the EVGA Supernova G2 750W.
You can also buy braided cables - http://www.performance-pcs.com/cablemod-e-series-g2-p2-cable-kit-black-green.html
                                                       http://www.performance-pcs.com/cablemod-e-series-g2-p2-cable-kit-green.html
Swap the WD Black for something like the Hitachi Deskstar 2TB 7K2000 - http://pcpartpicker.com/part/hitachi-internal-hard-drive-0f10311
Better SSD (imo) - http://pcpartpicker.com/part/crucial-internal-hard-drive-ct256mx100ssd1
https://linustechtips.com/topic/314789-my-first-pc-build/#findComment-4280633
