Hey all! I am looking for advise on this build before I buy it all. I will be buying it in the next hour or 2 so replies would be much appreciated and thank you in advance. I am from Ireland, looking for a long lasting all round build with heavy hours of gaming intended. I will not and have no interest in overclocking and like visuals/performance over low-price/performance. I am a Intel and NVIDIA fan boi.
Any advise on all of this and dose it all Fit or do I need to change something and do I have enough cables and things of that sort?
RAM: Corsair Vengeance Low Profile DDR3 1600MHz
CPU: Intel i5 4690 3.5GHz Haswell Refresh
MOBO: ASUS MAXIMUS VII RANGER Intel Z97
GPU: EVGA GTX 970 FTW 4GB GDDR5
SSD: Samsung 850 PRO 256GB 2.5"
HDD: Not getting one as I will be buying a second SSD
PSU: Corsair RM750W Full Modular 80PLUS Gold
CPU Cooling: NZXT Kraken X61 Liquid Cooling
Case: NZXT H440 White
OS: Windows 8.1
Peripherals,
Headset: Razer Kraken Chroma 7.1
Keyboard: Razer Blackwidow Chroma Stealth
Mouse: Razer Taipan White
Anything missing?
https://linustechtips.com/topic/314338-first-build-advise/
no point is z 97 for a non oc cpu get a 4690k or a h81 board
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/314338-first-build-advise/#findComment-4273246
The ROG boards are overpriced as it is, and you'd either want a K (unlocked) CPU for the Z97 chipset, or go for a H97 or other chipset with the non K CPU.
I would advise going with an MSI Z97 Gaming 5 board and a 4690K. It should be cheaper and perform better.
I'd go for a cheaper SSD too. The 850 Pro is not worth the price. Something like an 840/850 EVO is a good SSD for the price.
PSU is overkill. 600W is more than enough for this build. This PSU is a better choice http://pcpartpicker.com/part/seasonic-power-supply-ss650km
Or you could go for the EVGA 750w G2 if you plan on SLI.
https://linustechtips.com/topic/314338-first-build-advise/#findComment-4273306
