I plugged in a second monitor.. now the clock is always at max. temp is always @ 50°C, goes to 65 max while playing csgo. so it's not a dire situation.
I'm just wondering if it happened to anyone else and how they fixed it.
I could troubleshoot, but cba.
nvidia control pannel says power option is set to adaptive not performance. so it should be idling when I'm on the desktop.
anyway it's no big deal, just a little annoying to have the fan speed at 50% because the card won't idle.
SPAAAAAACE!!!
https://linustechtips.com/topic/313482-gpu-will-not-idle-max-clock-always/
Manually tweak the settings or try using a diff. monitor/display cable?
My life is consumed by CS:GO, even though I'm not exceptionally good at it.
CPU: AMD A10-5800K | GPU: Gigabyte R9 270 2GB | RAM: 8GB 1333Mhz HyperX Blu | Storage: 120GB Samsung 850 EVO + 1TB WD Caviar Blue | Chassis: NZXT H230 | Mobo: Gigabyte GA-F2A88XM-HD3 | PSU: Corsair CX500 500W | Cooling: CM Hyper 212 EVO | OS: Windows 10
In order of priority: GTX 970 Strix, 2 good 1080p monitors, i5 4690k, MSI Z97 Gaming 5 LGA 1150, a job
