Just built a desktop! few problems
Yeah thank you for all the help.
I will install OS and see what happens.
Quick question, Does the bios automatically directs me to HDD that has OS once the OS is installed even if the boot order is not changed (lets say highest boot order priority is on USB)
Yes. Once you have the OS installed it will automatically go to the boot drive by default. Even if you have it set where the boot drive is the last option of 10, it would recognize that those other options do not have a bootable program available (unless you put one there) so it will automatically skip them until it gets to the drive with your OS. After you get the OS installed you can go into the BIOS and check to make sure that the boot drive is set as the first boot option if you want to be safe.
