i accidentally spilled water (just a tiny bit) on the top of my pc but a few drips hit the connecotors (not really sure what theyre called in english) and now i cant hear anything from my headphones. Barely any water went to the connectors but i cant hear anything...what should i do? open up the pc and try to inspect the connectors from there?
CPU Intel Core i5 6600k @ 3.5GHz GPU MSI Radeon R9 380 4GB Motherboard Asus Z170 Pro Gaming RAM Kingston Fury 2x4GB DDR4 2666MHz PSU XFX 650W Storage Seagate 1TB, WD Blue 1TB, Kingston 128GB SSD OS Windows 10
https://linustechtips.com/topic/312079-i-need-help-fast/
Turn it off now. Leave it for 48 hours to dry out and then try again, with any luck you will get lucky and it will work fine.
Azure Fists - "Grown men playing with each other since 2009"
CPU : Intel® Core™ i5-4590T, OS : Windows 10 64bit + Custom Alienware Console Interface, GPU : NVIDIA® GeForce® GTX 860M 2GB GDDR5, RAM : 8GB Dual Channel DDR3L 1600MHz, SSD : Kingston V300 240GB, WIFI : Intel® Dual Band Wireless-AC 7265 2x2 + Bluetooth 4.0, CASE : Alienware Alpha, PSU : External Power Brick, MOBO : Custom Dell Motherboard.
CPU : i5 6600, Mobo : Asus Z97i-Plus, RAM : 16GB DDR4 3000mhz Corsair Vengeance LED, GPU : Gigabyte G1 GTX 1080, Case : Silverstone RVZ02, Storage : SanDisk 1TB M.2, PSU : Silverstone Strider SST-SX700-LG, Display(s) : AOC Q2963PM 29" IPS Ultra Wide 21:9, Fans : Noctua NH-L9i with Be Quiet Pure Wings 2, Keyboard : Razer Blackwidow Stealth 2015, Mouse : Razer Naga 2015, Sound : LG Wireless Soundbar /Razer Kraken Pro, OS : Windows 10
https://linustechtips.com/topic/312079-i-need-help-fast/#findComment-4241540
If it's just pure water just shut it down and take out the battery (basically don't electricity get anywhere near) and let it dry out.
If it's not just water, you might need to open it up to clean the residue.
But unless there are a membrane keyboard and residue involved (in which case you should wash it out asap), just let it dry.
https://linustechtips.com/topic/312079-i-need-help-fast/#findComment-4241547
well it was milk...
https://linustechtips.com/topic/312079-i-need-help-fast/#findComment-4241554
well it was milk...
That's not water...turn the system of and clean it with a micro fibre cloth (don't use a towel or kitchen paper etc) then let it dry out for 48 hours. Good luck.
https://linustechtips.com/topic/312079-i-need-help-fast/#findComment-4241561
