Sky Go Issues
Go to solution Solved by Jimbillroo Digital,
It's fixed. The solution was to play the video on the website for Sky Go while downloading it, so it assigns security information to your system.
"Have you tried turning it off and on again?"
Code of Conduct ■ Suggestions ■ Report a Bug ■ FAQ with Windspeed36 ■ Useful Links ■ Memes
https://linustechtips.com/topic/311111-sky-go-issues/#findComment-4228818
