Hello everyone, I just bought a new VGA name " Gigabyte R9 270x " for about 3 months. When i played games like Starcraft 2, Far Cry 4 or Skyrim, I got these " problems ".
First problem is artifact
"'https://www.facebook.com/video.php?v=711374685627804&pnref=story"
Second problem i don't know how do you guys call it
"https://www.facebook.com/video.php?v=708447589253847&pnref=story"
It happens randomly. My GPU temperature is only about 50~ 65 degree
Sorry for my bad english , i recorded by using my Phone so i only can upload it to Facebook only. Please i really need some help for that VGA
CPU:Intel® Core™ i7-3930K Processor Ram:Kingmax 2GB DDR3/1333Mhz VGA:Asus R9 290 Direct CU II HDD:Seagate Barracuda 250GB Mainboard:Asus Sabertooth X79 TUF
PSU:FSP SAGA 650w
https://linustechtips.com/topic/308963-vga-problem/
I see you have the latest drivers and you say your temps are fine, the only thing i see WRONG in the picture you posted is that in the BUS INTERFACE section it says
"PCI-E 3.0X16@ x4 1.1"     What motherboard are you using? But most important WHY are you using a x4 PCI-E lane? When your GPU is idleing it should be read as this:
"PCI-E 3.0X16@ x16 1.1" And when you stress the card, that "1.1" should rise to "2.0", "2.1" or "3.0" depending on your PCI-E version, but that x4 means you have the GPU inserted in a x4 slot.
Please specify the motherboard you are using and if you can USE the x16 lane.
CPU AMD FX-6350 @ 4.5Ghz 1.284v Motherboard ASUS M5A97 R2.0 Memory 4x2GB ADATA XPG Gaming v2.0 1600Mhz CPU Cooler Corsair H100i
GPU MSI 270x HAWK Edition Display HP w1907 Storage 1x Samsung 850 EVO 128Gb SSD 1x 400GB Hitachi HDD Case Corsair 450D PSU Corsair CX750M Semi-modular
Keyboard Logitech G105 Blue LED Version Mouse Microsoft Basic Optical Mouse v2.0 Audio 2x Logitech x230 for a Quad-Channel speaker setup OS Windows 8.1
https://linustechtips.com/topic/308963-vga-problem/#findComment-4199403
Hi Juan , thanks for the quick reply . My mainboard is GA-H77M-D3H " Gigabyte " , i have  2 PCI x16 sockets, i'm testing the 2nd socket so i put my graphic card on the 2nd socket. Let me try and put it back at the 1st one
P/s : Update 34_zpsc013e2c1.gifyeah it rise up to 3.0 and x16 , sorry because i don't install the VGA right way now its x16 let me test see if the problem still continue or not10960079_710464575718815_715728962053070
PSU:FSP SAGA 650w
https://linustechtips.com/topic/308963-vga-problem/#findComment-4199488
PSU:FSP SAGA 650w
https://linustechtips.com/topic/308963-vga-problem/#findComment-4200234
I see one weird thing in there, BIOS version...
I have already checked the bios update . Lastest version
PSU:FSP SAGA 650w
https://linustechtips.com/topic/308963-vga-problem/#findComment-4200303
Juan Remes GPU-Z image, with the same GPU (R9 270x) but a different brand (MSI), has a much newer BIOS version if you look at the numbers.
I don't have much experience with AMD graphics cards but I do know that they break/are broken alot. You might want to try RMA'ing it. :(
https://linustechtips.com/topic/308963-vga-problem/#findComment-4200932
True true but what is RMA'ing? Sorry imma newbie =(. Btw im using OC Guru II to find a new BIOS update but it can't seems to find it @@ . It already said that no any updates
P/S: damn Weet you are right there are some new BIOS update at the Gigabyte Website . Imma try to update it now
PSU:FSP SAGA 650w
https://linustechtips.com/topic/308963-vga-problem/#findComment-4201115
Done now i am the same as Juan 015.041.000.000.000000. The problem is still there though jeez ToT
PSU:FSP SAGA 650w
https://linustechtips.com/topic/308963-vga-problem/#findComment-4202020
If you did update the Bios and there is still the problem, yeah you should RMA it, it means you make valid your guarantee, contact the store where you purchased your GPU and ask for a replacement, because the GPU came bad from factory
https://linustechtips.com/topic/308963-vga-problem/#findComment-4202194
Yeah at first , I use VGA@Bios by Gigabyte and it's not working . It said that flash bios failed bios version not match . So i have to use AtiWinFlash to flash my Vbios. The problem is still there LOL
PSU:FSP SAGA 650w
https://linustechtips.com/topic/308963-vga-problem/#findComment-4202330
Don't use third party tools, just return the graphics card to the shop as it's a bad/broken one :(
https://linustechtips.com/topic/308963-vga-problem/#findComment-4204379
Okay, i will thanks for taking time for me though . Thank you guys a lot :P
PSU:FSP SAGA 650w
https://linustechtips.com/topic/308963-vga-problem/#findComment-4206747
