Difference between OpenCL and OpenGL
Solved by fizzlesticks,
is it a problem for professionals that CUDA is not open-source?
Programming and usage wise, no. But in the future when upgrading hardware you're either stuck with buying more nvidia cards that may not be the best you can get or spending a ton of time and money rewriting all of your code in OpenCL and getting AMD.
