Help, capslock doesn't work
Go to solution Solved by Guest,
Just take out and put back in the USB cable to reset the motherboard.
And when I look at the on-screen keyboard it isn't being 'ghost' pressed either.
It just won't activate anymore, no light to show it's on and no capital letters.
It's a Corsair K70 RGB
EDIT:
Nvm, it seems one of the lighting profiles has had this effect, caps lock doesn't work with it for some reason.
Stupid profile maker *grumble*
https://linustechtips.com/topic/308475-help-capslock-doesnt-work/
