THE INCLUDED ONS SHOULD BE FINEcaps
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
https://linustechtips.com/topic/308054-help-please-p/#findComment-4186416
Hi, I´m building a PC and I am going to use the CM Hyper 212 EVO.
I was wondering if I should buy some other thermal compound, or the one included in the cooler is good enough.
Thanks for the atention and your answers, you are an awesome community :);)
Stock should be fine but I'd buy some extra in case you have to re-set your cooler
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/308054-help-please-p/#findComment-4186565
