So I recently built myself a gaming pc, which I am going to eventually build myself a few websites ect and needed a good pc to work with my specs are as follows:
Asus Rampage extreme iv black edition
Intel i7 4930k 2011 extreme
Kingston hyperx beast 32gb 2400
amd r9 295x2
Alphacool water cooling kit
corsair ax1200i
windows 7 64 bit
I managed to finish this build I then installed windows and can run everything as stock from what I can see, so the problem is Itry overclock using existing profiles in the rampage bios and it ends up not booting, how do I overclock my 4930k to a good stable speed with this setup so it will boot and be faster than stock and stable? secondly my ram is set to 1600mhz in bios I try to change this and when i change it the same thing happens system crashes I have to reset bios and when it posts again to the first screen error message overclock has failed appears. Any help or setting suggestions would be welcome and many thanks in advance for those who reply.
https://linustechtips.com/topic/308032-overclocking-help-needed/
dont use the profiles.  make small incremental adjustments manually.  start with a manual voltage of 1.35 and slowly (and incrementally) increase the clock multiplier
don't worry about the ram for now - you probably will need to give it some extra voltage, but dont go trying to OC both ram and cpu at the same time.  do the cpu first.
work rig
cpu: AMD 5800X mb: Pro WS X570-ACE cooling: NH-D15 ram: 32GB Corsair 3200mhz ssd: Samsung 970 Pro 512GB, 860 Evo 512GB   hdd: 4TB Seagate, 320GB gpu: Asus RTX-1060 6GB psu: Corsair RM750x display: Philips 32" 4K case: Fractal Design Define R6 Black
home lab and NAS
cpu: Xeon E5-2697 v2 (12c/24t) mb: Rampage 4 Black Edition cooling: Hyper 212 EVO ram: 64GB Corsair 1866mhz ssd: 2x Intel DC S4610 (480GB), 2x Intel DC P3605 (1.6 TB)  hdd: 4x Seagate IronWolf 4TB CMR, Seagate Exos 7E8 8TB, WD VelociRaptor 10K 450GB  gpu: Asus GTX-660 psu: Corsair HX850i case: Corsair 750D
https://linustechtips.com/topic/308032-overclocking-help-needed/#findComment-4186217
Ok I will try this, somehow I have the cpu running from 3.4 to 3.9 now and the ram is running at 2133, could I have had something set in bios which was conflicting with the overclock making it not boot or give errors? it seems to be running now at higher speeds so this tells me that there is nothing wrong with the hardware in my machine, thanks for the reply
https://linustechtips.com/topic/308032-overclocking-help-needed/#findComment-4186864
1) set the XMP profile for the RAM
2) set voltage to manual, enter:
vcore: 1.275v
VCCIN: 1.875v
3) set multiplier:
Core: all matching @ x43, do not use per core optimization or any other funky settings
If that boots and the system is stable in XTU/AIDA64, go from there. If you feel like OCing cache do that after you find a stable core clock.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/308032-overclocking-help-needed/#findComment-4188750
I shall try these suggestions many thanks for the replys, I have a different problem at the moment and that is that my gpu is playing games very badly and choppy, I have a amd r9 295x2 with a 4k, should play games like watchdog and call of duty easily and very smooth but it chops more than a blender on full speed.
https://linustechtips.com/topic/308032-overclocking-help-needed/#findComment-4195395
