Front Panel Mounted Loop?
Solved by Bosco,
Hi all,
wanted to get your opinions on my systems custom loop.
I especially am wondering about the parralel loop between the gpus.... anyway, here are some picture diagrams...
What do yall think....
2 res for looks I'm guessing? as long as you get a parallel bridge for the gpus it should be fine.
I'm not a watercooler, but the loop looks good to me, however, why are the resivoirs on the door?
Looks / saving room in the case my guess
