Ok, so i am getting this error when im logging into windows "WHEA_UNCORRECTABLE_ERROR" and i researched it some and people where saying that it was a voltage issue so then i went out and bought a 750w power supply from EVGA. from a 430w PSU Then i tried to overclock again with the same settings and it still gave me the same error and i do not know what to do about it please help.
PSU: EVGA SuperNOVA NEX 750 G 80 PLUS GOLD
CPU: i5 4690k
MOBO: ASUS Z-97 A
Cooling: CM 212 EVO
Motherboard:: Asus Maxiumus ROG Crosshair VII AM4     Ram:: G.SKILL TridentZ RGB Series 16GB (2 x 8GB)     SSD:: Intel 730 series 240Gb SSD
 GPU:: ASUS GTX 1080 8GB ROG Strix     CPU:: AMD Ryzen 7 2700x @3.70GHz   COOLING:: NZXT Kraken x72 AiO, 3x Thermaltake Riing Plus
https://linustechtips.com/topic/307711-i5-overclock-issue-error/
Not stable, increase the voltage on the CPU/ decrease the Clock speed.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/307711-i5-overclock-issue-error/#findComment-4181287
It was at 1.2 voltz both times i used linus' setting on hos i5 i7 overclock guide
https://linustechtips.com/topic/307711-i5-overclock-issue-error/#findComment-4181293
Try feeding the cpu some more voltage.
Over 1.3?
https://linustechtips.com/topic/307711-i5-overclock-issue-error/#findComment-4181306
When overclocking, you need to go into it with an open mind.  Don't try and recreate someone else's results.  Focus on getting the best overclock for your specific chip.  I would not go above 1.3v.
Here are some guides, but the most important thing to know going into this is to keep an open mind.  Don't try and compare your results to others, just focus on getting the best result for your chip that you are comfortable with. Also, whenever you stress test, make absolutely sure that you set your voltage to manual before stress testing.  When you are done stress testing, revert back to adaptive voltage.  Failure to do so can cause overheating and overvolting which has the potential to damage your chip.  If you do everything as instructed, and keep a low voltage below 1.3v, you will be fine.
To start, do some research.  Understand what all of the terms mean, and wait to play with your settings until you understand everything.  I am here to help if you need it, I have the same motherboard, and the same processor(i5-4670k), but please become aware of what the different terms mean and where to find them.
http://rog.asus.com/...or-Overclocking
http://www.wikihow.com/Overclock-a-PC
https://teksyndicate...ng-guide/153447
http://www.overclock...with-statistics
http://linustechtips...clocking-guide/
Load Line Calibration, Why Overclockers Should Care
The LLC setting was the one setting that the Asus auto overclock does that is not good.  It sets it to the maximum value, which is not good, it causes vBoost(overvolting).  You want this set to 2-5 out of 8.
Try increasing voltage to 1.25 for now, see if that fixes things.
It is good that you bought a better PSU, because 430W is cutting it close for an i5 and R9 270X, but PSU was not the problem, it was the settings.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/307711-i5-overclock-issue-error/#findComment-4181322
Then is there anything that i have to manually switch on the motherboard. Because i looked into it and it had some switches on the mobo physically and i didnt know if that affected anything?
https://linustechtips.com/topic/307711-i5-overclock-issue-error/#findComment-4181352
You shouldn't be touching anything on the physical mobo.
https://linustechtips.com/topic/307711-i5-overclock-issue-error/#findComment-4181431
Where did you acquire this idea as the next course of action? This whole thread has said that it means your voltage isn't enough for your clocks.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/307711-i5-overclock-issue-error/#findComment-4181448
DO NOT touch the TPU/EPU hard switches on the mobo, especially if you have no idea what their purpose is or how to use them. Leave them on default. As everyone else has said, kick your voltage up a notch and retest.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/307711-i5-overclock-issue-error/#findComment-4181503
