My first build :D
Go to solution Solved by Str_Mape,
This is the build I'd go with.
More reliable SSD, colour matching motherboard with a similar feature set, lower cost same spec ram, fully modular PSU with room to go SLI and you can switch to 750W version if you prefer and still keep the build cheaper than $1380.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($214.89 @ OutletPC)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($123.99 @ Amazon)
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card  ($544.99 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($62.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $1359.68
Generated by PCPartPicker 2015-02-09 16:12 EST-0500
But do you guys think i could pick up any triple A titels and have them over 60fps at 1080p
Yes
Budget? Use? Kindgston V300's suck, get a Crucial SDD.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/307524-my-first-build-d/#findComment-4178554
seems to be a fine build. maybe you can find some 2133mhz Ram for almost the same price.
for the OS you can buy a Windows 8.1 instead of the original 8.
"Well, not even last night's storm could wake you. I heard them say we've reached Morrowind, I'm sure they'll let us go."
https://linustechtips.com/topic/307524-my-first-build-d/#findComment-4178576
If the original 8 is cheaper then go with that, you get 8.1 free.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/307524-my-first-build-d/#findComment-4178589
Need some help with this... My first build so tell me if the case is small to work in... Any tips is helpfull :D
http://pcpartpicker.com/user/spacerumbler/saved/YJqV3C
looks great to me, faster ram not necessary.
whats wrong with the v300? I have had nothing but great experiences with these puppies.
When in doubt, re-format.
https://linustechtips.com/topic/307524-my-first-build-d/#findComment-4178590
They downgraded the flash. It's barely faster than an HDD.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/307524-my-first-build-d/#findComment-4178608
I haven't found that to be the case. I have deployed 6 or 7 of these over the last year and a bit and have found them to be quite fast (~400mb/s r/w)
https://linustechtips.com/topic/307524-my-first-build-d/#findComment-4178630
anything above 350MB/s is reaching totally irrelevance for 95% of use cases.
You can get much better performance for a bit more. They just aren't worth it.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/307524-my-first-build-d/#findComment-4178647
Total: $1359.68
Yes
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/307524-my-first-build-d/#findComment-4178687
