So I have a 200r and thinking about painting the side panels. I freaking hate the one with the vents on it. Just looks bad to me. I am thinking about buying another solid side panel from corsair's website. Would this have any REALLY negative effects on the cooling of my case?
01101100 01110110 01101100 00100000 00110101 00100000 01101101 01100001 01100111 01101001 01101011 01100001 01110010 01110000
https://linustechtips.com/topic/307455-200r-side-panelairflow-question/
nope it wouldn't, the side panel vent is for GPUs that need an extra fan blowing on them, buy the soild one you won't notice it
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
