Hi, i would need some help with my new Pentium G3258. It wont boot on my Asus B85m-E i have updated the newest BIOS to it (version 2201) and the mobo was on the supported list. So it doesnt boot it doesnt post anything fans does spin. So what should i do?
https://linustechtips.com/topic/307327-pentium-g3258-help/
How does the fans spin up if the psu is off?
https://linustechtips.com/topic/307327-pentium-g3258-help/#findComment-4175268
Oh sorry i somehow read they didnt spin... Does it show any postcode (if it has a postcode display), how is the drive activity led and are all the displays plugged properly?
it does boot up with my other pentium g3430 and there is no post display but i have a post speaker that beeps at the boot with 3430 but it doesnt beep with the 3258
https://linustechtips.com/topic/307327-pentium-g3258-help/#findComment-4175301
Try reseating the cpu... Helped me a lot
i have changed between the g3430 and g3258 so its reseated many times but still doesnt work?
https://linustechtips.com/topic/307327-pentium-g3258-help/#findComment-4175330
Could be a dud CPU then. Might want to take it back and exchange it.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/307327-pentium-g3258-help/#findComment-4175640
Thank you to all of you who responded but i fixed it myself. The solution was that i needed to update my bios with asus bios update software on windows and then it started to working and it overclocked even to 4.4GHz
https://linustechtips.com/topic/307327-pentium-g3258-help/#findComment-4176050
