Fully modular psu? 750w?
By
Mrbluee
in Power Supplies
in Power Supplies
Solved by quan289,
What will you be powering?
Do you think ill be able to plug in bitfenix alchemy straight away or do i still have to plug them into the wires
You're talking about the bitfenix sleeved cable? They work work with all power supply, as they are merely extensions. In other words, you need to hook it up to the cables that came with the PSU.
1
toxic_worper ·
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning6
