Okay, so I'm currently working my own PC case. I've done pretty much everything but the front I/O isn't ready yet (or the painting).
So here's my question:
Can I use any switch as an on/off button that I can buy from any electric component retailer or do I have to use some kin of proprietary on/off button.
Sorry for my poor english :D.
Thanks in advance
https://linustechtips.com/topic/305994-pc-power-switches/
Any push button switch would do, in fact virtually any single pole switch at all if used right (eg a toggle switch would need flicked on then off again to start).
All you are doing is completing a circuit when you press the button then releasing it right after.
https://linustechtips.com/topic/305994-pc-power-switches/#findComment-4158745
